TwinTurbo.NET: Nissan 300ZX forum - Re: While replacing the pan you'll also get to replace
Subject Re: While replacing the pan you'll also get to replace
Posted by ttzxna on February 16, 2011 at 9:36 AM
  This message has been viewed 125 times.
In Reply To While replacing the pan you'll also get to replace posted by CoHPhasor on February 15, 2011 at 10:21 PM
Message :the likely shady pan seals.
Speaking of seals, hope you did all the valve cover gaskets and the coolant deletes while you were in there.
what is the easiest way to pull the pan in your opinions. the motor is inthe car. do you think it would be easier topull the whole thing back out ? or should i follow the manual per [ http://www.300zx-twinturbo.com/cgi-bin/manual.cgi ] ?
